Missing a profile
Mads
Missing a profile
Post by Mads »
Hi Guys,
I've recently setup my second bike (summer) with the Newton and seems to work great and I used the profile number 2 as I have the front mount on this bike. However, when looking in Isaac under Device, Set profile there's only profile number 2 and not the first one I've used for my first (winter bike). A part from profile 2 all the others says unsaved (type: initial setup) Although, if I go to edit, edit profiles I can see my two profiles which are Cannonsdale Cross (winter) and Road Bike Prof 2(summer).
Is there some way I can save the winterbike profile under profile 1?
Re: Missing a profile
1. Connect your Newton to Isaac.
2. Go to Edit/Edit Profiles.
3. Select the winter bike profile you want to store in profile 1 of your Newton.
4. In the Edit Profiles window, set the active profile in Device to Profile 1
5. Click the Send to Device* button.
Your winter bike profile will be stored in profile 1.
