Ok so I finally got some coast downs...
Derath
Post by Derath »
And a 4 mile ride. How can I tell if it is any good? This is my first foray into power so I don't know what at all to expect.
-D
rruff
Re: Ok so I finally got some coast downs...
Post by rruff »
As it states in the manual, you can put it on the "coast" screen and see what your power is while coasting. Ideally it should be close to zero.
Also, look at how much scatter you got in the CDs... wildly varying values aren't a good sign. Another check is to look at your CdA and Crr values and see if they are close to reality.
Derath
Post by Derath »
rruff wrote:As it states in the manual, you can put it on the "coast" screen and see what your power is while coasting. Ideally it should be close to zero.
I had tested my coast downs on the coast screen and they looked good.
My CD's were all pretty close except one.
I have no idea if my Cda and Crr values are close to reality
Cda .3774
Crr .00292
rruff
Post by rruff »
Crr looks a bit low. This is mostly tire rolling resistance. If you have the best racing tires and latex tubes, you can get ~.004. More typical values with good tires and butyl tubes are in the .005-.006 range. Some tires will be higher than this though.
It is difficult to get an accurate Crr out of the coast downs unless you do a lot of them and have very good conditions. iBike tries to extract CdA and Crr from the coast-downs by applying a curve fit, but you can end up with Crr being off in one direction and CdA will be off a little in the other to compensate. Frankly I'd I think it would be good to have the ability to tweak the Crr manually, and have iBike adjust the CdA to appropriately. I've been playing around with doing my own CD analysis. If you really want to get those #s right it is best to do the CdA at high speed and Crr at low-speed.
Derath
Post by Derath »
Hmm,
Dunno if it matters but my fric number was 1.45
The reason I was curious is that my first real ride with the ibike after doing my CD's and 4 mile ride seemed to have better power numbers than I expected. Not that I know what to expect. I just know that currently I am in lousy shape.
I am running Continental Ultra race 700x23 at 115psi.
rruff
Post by rruff »
If I had to guess I'd put your tires close to .006 on Crr.
The Fric number combines the tilt correction and the Crr since they are physically identical. What is your tilt adjustment? It is possible that this is off. For instance if your tilt is off by .1% this is identical to a .001 change in Crr. If you do some rides and notice that your slope is off in "analyse tilt and power" then you will know...
Derath
Post by Derath »
rruff wrote:If I had to guess I'd put your tires close to .006 on Crr.
I highly doubt my tilt is off. I have checked it numerous times and it checks out. The mount is rock solid. and during rides the grade is pretty much in sync with my Garmin, given that the garmin lags a little it isn't always exact but pretty darn close. And close to exact on long steady grades.
[edit- some stuff to add. didnt have time earlier]
For my coast downs I found a stretch of road that had been recently paved. Low traffic. I didn't get buzzed by any cars during any of the CD's. It was very slightly uphill (registered +.5%). Every time I did a CD I made note of my start and stop and they pretty much were right on.
Attached it the tilt calc from my 4 mile ride.
-D
4 mile ride tilt calc.jpg (209.44 KiB) Viewed 11059 times
rruff
Post by rruff »
Go to the advanced tab in the "analyse tilt and power" page. There you can see if your tilt matches the elevation. If your tilt is typically good (errors of more than .1% are big enough to do something about), I'd recommend increasing your Crr to .006 and reducing your CdA to ~.36. This is "unauthorized" of course (the VC guys might have other ideas), but I have some experience with this stuff.
Derath
Post by Derath »
funny I was editing my reply while you added yours. See above
rruff
Post by rruff »
Derath wrote:funny I was editing my reply while you added yours. See above
Your tilt looks good... only .05% off. So this is with a tilt correction of zero? Most people seem to be getting around -.5% for a tilt correction (difference between riding tilt and the unladen tilt cal). If it stays this good on subsequent rides then it is fine. Did you do a tilt cal before the CDs and check it afterwards to see if it stayed the same?
Derath
Post by Derath »
Yes I checked my tilt before my CD's I did not immediately afterwards. But I did check it before my next ride and it was fine.
Now I can't exactly remember, but I know the wind had started to pick up a little when I was doing my CD's Not bad, but any wind would have been a tailwind while I was coasting. I guess maybe that could have skewed my numbers maybe?
rruff
Post by rruff »
If your tailwind was ever higher than 8mph, then it could have affected your results. The iBike doesn't register negative wind.
travispape
Site Admin
Post by travispape »
rruff wrote:If your tailwind was ever higher than 8mph, then it could have affected your results. The iBike doesn't register negative wind.
Exactly! A tail wind during coastdows can mess up the fric & Crr measurement. It is more of an issue in the winter, but a bad wind offset can also mess this up.
Travis
Derath
Post by Derath »
Ok,
I got another coastdown and ride this weekend. On a local MUP so a bit more sheltered and controlled.
I did a tilt calc and wind offset immediately prior to the ride. I got 7 coastdowns and then my 4 mile ride.
I got the following numbers
Aero 0.362
Fric 5.958
Cda .380
Crr .0040
Seem better?
