Fit Plot Button
philatlondon
Fit Plot Button
Post by philatlondon »
What does the Fit Plot button do in the iBike 2 and how does one use it? I've searched the instructions and couldn't find anything on it.
alienator
Re: Fit Plot Button
Post by alienator »
Good question.
Answer?
Be an organ donor. When you're dead, you won't need 'em.
Re: Fit Plot Button
Say for instanace you are in the analyze tilt and power screen and you are working with it maximized to full screen size, if you restore the window size to a portion of the screen you will not see both the upper and lower graphs clearly. The fit plot button balances the view of the two graphs.
travispape
Site Admin
Re: Fit Plot Button
Post by travispape »
What Fernando says. The plot areas grow just fine when you make your window bigger; however, they do not shrink when you make your main window smaller. The "Fit Plot" button will fix the vertical size of each plot area so that you can see all the signals without having to use the vertical scrolling.
Also, note that you can change the size of each plot area by dragging the horizontal plot area bars shown in the picture. You can restore the sizes of the plot area by using the "Fit Plot" button.
plot area bars
plot area bars
Travis
