My first PP ride
beermat
My first PP ride
Post by beermat »
Hi all,
Attached is my first ride data with the PP. It was a reasonable length ride however the wind was gusty in places.
Can you comment on whether the ride data looks OK or whether I should perform another calibration ride when there is less wind?
If the ride looks OK is the next step to use the check calibration function in Isaac? I did look into this but the dial was all the way to the extreme right indicating significant changes.
Thank you.
iBike_02_28_2017_0935_37_Miles.ibr
(477.26 KiB) Downloaded 261 times
Re: My first PP ride
Check Calibration will adjust your profile correctly.
Use this feature, then send the profile to your PP to get things in best shape.
beermat
Post by beermat »
Please could you check this ride file? Does it look ok?
iBike_03_04_2017_0936_51_Miles.ibr
(915.56 KiB) Downloaded 301 times
Yes, this one looks just fine!
beermat
Post by beermat »
Thank you so much for the support.
