Zero Breaking
- lorduintah
Zero Breaking
It is likely that using 5 second recording intervals that breaking does not show up as any contribution? Correct? I changed from 1 second intervals and a low percentage went to zero.
Re: Zero Breaking
If' you're talking about the "breaking" stat in the iBike 2 software, then remember that you have to analyze your ride before this number will appear.
- lorduintah
Re: Zero Breaking
John -
Have done so. Or I never stopped or slowed down;-)
When I used the 1 second rate, I would get about 2% breaking as a typical factor for the same ride.
It looks like I break so little anyway that at the 5 second record interval, breaking is not often captured. I am getting 0.5% on some ride.
