Changes to Customised Profile
Bugsbunny
Post by Bugsbunny »
Hi John
A while back you customised/tweaked my PP profile.
However, I have since changed my bike from 25mm tires to 28mm tires.
My question is, can I/should update my wheel settings to 28mm? Will this affect the customimsed settings in any other way negatively?
I guess this would also apply to my body weight. I've since gained a couple of kilos. So in the same vein, shoudl I just update the weight, or do I need to do a whole calibration run again?
Whats the best thing to do?
Re: Changes to Customised Profile
Update your values, do an out and back ride, and post the results. I'll be glad to check them for you.
