Help calibration after Update PP
Sergioperi
Good day,
I have follow the steps you bring me to re calibrate my PP after last firmware update.
Here you are .ibr file of ride calibration and my ride of today after this.
Please, could you check it? I have observe higher wtss than before.
Regards!!
Regards!!
- 02_08_2017_0011_43_km.ibr
- (362.45 KiB) Downloaded 335 times
- 02_08_2017_0000_4_km_CalRide.ibr
- (42.1 KiB) Downloaded 330 times
Re: Help calibration after Update PP
Actually, your ride files are perfect.
It looks like the new O&B calibration improved the accuracy of your device.
Have fun!
Have fun!
Sergioperi
Thanks a lot!! I really appreciate your efforts to help us. A great product isn't only a good hardware, It's also all the people behind working to give the best to his customersVelocomp wrote:Actually, your ride files are perfect.
Have fun!
We really appreciate this!!!
here there is my O&B calibration ride. What do you think about it?
- iBike_02_06_2017_1725_4_km_CalRide.ibr
- (41.19 KiB) Downloaded 374 times
Thanks very much!!
Hi, I am new to PowerPod, just recently started to use, did the calibration ride and now updated the firmware and did the O&B ride.
I have two questions:
1. Can you please check if there is everything ok in my setup? The file with the O&B calibration ride are attached..
2. I tried to put the PowerPod on the handlebar as good as possible, but the wires are.. everywhere. Can you please check from the photos if it is ok like that, or should I do any changes? ( photos - https://www.dropbox.com/sh/gwenyzobzmv7 ... TZGha?dl=0 )
Thank you for your help, cheers, Petr
- iBike_02_15_2017_1246_10_Miles.ibr
- (123.95 KiB) Downloaded 331 times
- iBike_02_15_2017_1234_3_Miles_CalRide.ibr
- (45.99 KiB) Downloaded 341 times
- iBike_02_15_2017_1225_1_Miles.ibr
- (24.01 KiB) Downloaded 341 times
Hi John, Kudos for checking on it so fast. Thank you & I will go to study other topics in here:)
Hi John, so I tried to do a first longer ride with PowerPod in a windy weather and i was quite surprised that the wattage is pretty high... I would say at least.. avrg. 196 and Normalized some 245.
Can you please be so kind and check if there is everything fine with my setup after the O&B ride, which I did previously.
Thanks, Petr
Thanks, Petr
- iBike_03_04_2017_0848_92_km.ibr
- (662.87 KiB) Downloaded 353 times
Yikes, you DID ride in some major headwinds!
Your PP is calibrated perfectly (look at from KM 10 to KM 22) where there was little headwind.
Your nasty winds started at KM 50.
Yes indeed, starting km 50 or so it started to be really crazy:-) Thanks for the quick analysis, it felt as a hard ride, but still I was not sure that the watts shall be so high.
Thanks, Petr
Thanks, Petr
