Distance alternated with Power in the Power Screen? SOLVED
rbe
Post by rbe »
Can Distance be alternated with Power in the Power Screen? I seem to remember an adjustment for doing this before, after reading about it, but I can no longer remember.
>>> I repeatedly went through the manual and could not see how this was done. Maybe I missed it.... BUT, the way to do it is to go to the "Isaac for Newton" software program; select Device from the Menu, then select Configure Screen, to alter what measurements you see in your display, then I was prompted to then press the Select button on the device to effect the change.
Re: Distance alternated with Power in the Power Screen? SOLV
