A ride with my iBike and PowerTap
I have my trusty iBike Gen II on my bike as well as a variety of direct force power meters. Today, the DFPM was my PowerTap.
Earlier this year I used one of the new features of iBike 2 to determine my drag coefficients with and out-and-back ride where the PT is used as the direct-force power reference. This isn't "cheating"; rather, it's a way to have two different measurement devices (the iBike and the PT) be calibrated so that they perform similarly for a given set of ride conditions.
I rode 17 miles today on Montana chip-sealed roads, including the rumble strips on the side of the road. Prior to the ride I let the iBike acclimate to outdoor temperature, then I performed a tilt calibration and wind offset. That was it; the rest was riding.
After my ride I used the iBike 2 software to marry the iBike and PT files together.
I thought you might be interested to see the results. You can download and view the attached file; you'll find that the two devices differed by 0.1W (out of 160) for average power and by 38W out of 780W for maximum power (when I look at the shape of the power burst I find the PT peak data somewhat suspicious).
Also, play around some with the power meter comparison and you'll see that the moment-to-moment data is extremely close.
A lot of this ride was on reasonably flat roads where wind is a major factor. This means that the CdA and Crr measurements were very good. In general I held the same ride position for most of the ride; you should be able to tell from the CdA vs time analysis where I moved around some.
iBike_JH_07_03_2008_1525_17_Miles.csv
(385.38 KiB) Downloaded 311 times
Re: A ride with my iBike and PowerTap
Here's an image from the power meter comparison. The top graph shows power vs time; you can see that the two devices are virtually indistinguishable. The bottom graph is power differences which, again, are minimal.
Picture 3.png (73.01 KiB) Viewed 3863 times
michaeltop
Post by michaeltop »
Ditto for my IAero and powertap . This little fellow has really come of age.
Outstanding upgrades.
Thanks to the entire Ibike team.
Michael
