HI John
Been reading most of the threads and see you have given us lots of help in the form of after sales support, which is awesome in any standard.
Now I have got the PP and I think I have got it tune.
Just that for today ride, in the first 2.7km it did not kind of work, so stopped and spin the front wheels (where the speed sensor is on) and start riding again and got power figure but it was all over the place. (as in much higher than I think what actually is).
Then at 4.6km everything seem better.
please find the enclosed file.
Just wanted to see what may have caused it.
Also I am using 25C tubeless setup, so I wanted to ask what tire type I should choose.
Cheers
Leo
PP ride data check
PP ride data check
- iBike_10_23_2016_1541_15_km.ibr
- (109.75 KiB) Downloaded 255 times
Re: PP ride data check
It looks like your PP might be rotating some on your mount. This will cause abnormal high or low readings, until the auto correction takes effect. Make sure your PP cannot rotate on the mount.
Hi John
Great thanks ! Will check that out.
Cheers
Leo
Cheers
Leo
