Wind Scaling
powertothepeople
Wind Scaling
Post by powertothepeople »
New user here and quite impressed with the PP over-all. This is my first foray into riding with power so I have no real basis of comparison, but what I can say is that the power numbers seem "legit" - they respond almost immediately to surges, coasting, climbs, descents, drafting, just riding along, and are repeatable.
Pretty impressed, so far.
One concern though: I'm using profile 2 and I noticed that the wind scaling is set at 1.240 for the out-front mount; is that right? I've read here that it supposed to be 1.7
I'm also using my own mount which doesn't extend out as much (my head unit is a Garmin Edge 500) Is that the correct wind scaling? Sorry, but total noob here, just started using the PP.
I've attached my latest ride for your info (and if you can take a look and see if the numbers are all in order).
iBike_10_01_2016_0653_68_km.ibr
(743.84 KiB) Downloaded 332 times
ppod on mount.jpg (100.83 KiB) Viewed 9216 times
Re: Wind Scaling
Was this a group ride or a solo ride?
If a group ride, please do a short out and back solo ride.
powertothepeople
Re: Wind Scaling
Mostly solo. Rode with a group at 30km mark, for about 15kms (loops).
Re: Wind Scaling
Please do a short out and back ride (10KM is OK), then post the ride file.
powertothepeople
Re: Wind Scaling
Will do, thanks. Does riding around a loop (about 1km/loop) qualify as an out and back?
Re: Wind Scaling
powertothepeople wrote:Will do, thanks. Does riding around a loop (about 1km/loop) qualify as an out and back?
Yes, that will work just fine.
powertothepeople
Re: Wind Scaling
Hi John, here's my out and back ride file. Please note that the actual out and back (loops) began at around the 1.4km mark. I had to change the original route and restart the loops due to some traffic issues.
However, from the 1.4km point to the end of the ride (same as starting point), it was a pretty consistent ride, total distance was about 10.5km more or less.
Hope this will suffice, thanks for the help.
iBike_10_05_2016_1006_12_km.ibr
(125.25 KiB) Downloaded 346 times
Re: Wind Scaling
I used the command Analyze/Check Calibration... to correct your profile.
Load this profile into your PowerPod and you'll get much more accurate readings.
powertothepeople.ibp
(507 Bytes) Downloaded 336 times
powertothepeople
Re: Wind Scaling
Thank you John. Just to be sure of the procedure, in Isaac:
1. Edit Profiles
2. Import the IBP File
3. Select it
4. Send to Device
5. Pop up window: Profile Set
All good?
Re: Wind Scaling
powertothepeople wrote:Thank you John. Just to be sure of the procedure, in Isaac:
1. Edit Profiles
3. Select it
4. Send to Device
All good?
Correct!
powertothepeople
Re: Wind Scaling
Thanks John.
Just did the same out and back with the new profile you provided.
Looks okay, I guess...no comparison so I'll assume all is in order.
Got to do an ftp test soon...ugh :)
iBike_10_07_2016_1132_15_km.ibr
(162.44 KiB) Downloaded 299 times
maxcata
Re: Wind Scaling
Post by maxcata »
Hi John
I did the out&back calibration for both my road bikes. The mount that comes together in the Powerpod box is on bike #1, on bike #2 I have a Garmin combo mount.
Can you help me on checking both profiles? I have wind scaling values a little bit higher than the suggested values, especially on bike #2.
bike#1 calibration ride was made on a flat road with a lot of 90°turns, no wind, no traffic, no draft.
bike#2 calibration ride was made on a flat and straight road. It was lightly windy, and 5-6 cars overpassed me, no draft.
I am asking for your help because in the fine-tuning video I have seen that wind speed and wheel speed should be similar as more as possible. And they are not.
In attach profiles and calibration rides for both bikes (bike #2 on next post)
Thank you in advance
Max
iBike_08_04_2017_0652_2_Miles_CalRide bike#1.ibr
(38.86 KiB) Downloaded 374 times
bike#1_handlebar.ibp
(729 Bytes) Downloaded 314 times
maxcata
Re: Wind Scaling
Post by maxcata »
Bike#2 files follow.
thanks again
M
iBike_08_16_2017_1708_5_km_CalRide_bike#2.ibr
(52.46 KiB) Downloaded 311 times
bike#2_frontmount.ibp
(525 Bytes) Downloaded 298 times
Re: Wind Scaling
Cal ride for bike #2 is fine
Cal ride for bike #1 also is fine
Wind scaling depends heavily on the position of your PP on your bike.
maxcata
Re: Wind Scaling
Post by maxcata »
Thank you for your prompt feedback!
M.
Velocomp wrote:Cal ride for bike #2 is fine
