choosing power data to export
JamesB
Post by JamesB »
HOw can I select the power data source to export form Issac when I use the Newton with a DFPM?
I have done a ride and the Power2max battery died 1/4 way through the ride and the ibike continued to record power data.
How can I select the ibike power data from the entire ride to export, so far I seem only able to export using the P2M and therefor the last 75% of ride has no power data…
I suppose splitting the ride at the point of the P2M failure would be an option? are there others?
thanks
James
Re: choosing power data to export
Please post your ride file.
If this really is a problem then I agree splitting your ride file in two may be the simple thing to do.
JamesB
Post by JamesB »
yes, thanks
that worked
problem solved
JamesB
Post by JamesB »
Here is the file in question with P2Max data dropping out around mile 16
iBike_09_17_2016_0732_66_Miles_HiDef.ibr
(3.08 MiB) Downloaded 656 times
Yup, P2M most definitely died...
Pete
Post by Pete »
In the CSV export file copy and paste your iBike power column to the DFPM column
