incorect power
hutch1972
incorect power
Post by hutch1972 »
hello can you have a look at this power file please ,, i am finding sometimes im really impressed with the power pod and others its really really bad,,, ridin g to work this morning i was running a tiny bit late upping the power at around 7 k i am getting towards the thick end of 45kmh and really starting to try im on a fully open stretch of road heading basically north ,,, the wind doesnt feel much diferent and my effort is going up rapidly yet my power is falling and falling i think at one piont im doing over 40k under a 100 watts,,, on the flat ? what on earth has happened ,, i never take the pod off the bike and charge fitted ,,, p,s the pod is fitted right at the front with no cables any where near
morning commute.ibr
(62.12 KiB) Downloaded 232 times
Re: incorect power
Your PP profile looks normal and, at the beginning of the ride for the first 3.5KM you do not have any ground wind.
Your ride file shows a significant tail wind starting around KM 3.6. Were you riding in the draft of another bike?
Where your watts drop at KM 7.4, you are actually on a downhill -1% grade and in an 8KM/h tail wind.
You'll not that the tail wind is quite variable.
Also, there is variation in your cadence. Even a momentary reduction in cadence will cause watts to drop quickly
I think your PP is working correctly.
Screen Shot 2016-09-12 at 4.04.08 PM.png (830.08 KiB) Viewed 2916 times
hutch1972
Re: incorect power
Post by hutch1972 »
still find it hard to beleive i can hit that speed at even -1 % with a very very minor 8k tailwind and 80 watts!! and no i was never drafting .. also tonight i noticed if i pedal very slowly ( freewheel still clicking) i can get up to 30 watts when coasting yet if i stop pedaling it drops to zero ,,,,
Re: incorect power
Actually, at this point of your ride your tailwind is quite significant.
By any chance is this on a rougher road? If so, new FW just released will provide better results.
