ANT+ sensors missing or intermittent
BrianRC
Post by BrianRC »
Hi, I've just started using my new PowerPod for only a couple of days now and am struggling with getting is set up properly. Specific issues are it only sees my heart rate intermittently and does not pick up my cadence sensor at all. Also, the power seems to jump around quite a bit so I am wondering if i did not calibrate correctly from the start. I am also having difficulty getting powerstroke to operate but can save that issue for another time. I just came back from a ride that would qualify as an out and back but have not made any additional calibrations with it yet. I would appreciate your feedback on my profile. I'll attach the ibike file and the associated Garmin tcx file as well. Thanks very much for your help.
activity_1324264275.tcx
Same ride as recorded by Garmin 500
(2.57 MiB) Downloaded 213 times
iBike_08_27_2016_1724_16_Miles_HiDef.ibr
Out and Back iBike file
(585.22 KiB) Downloaded 254 times
Re: ANT+ sensors missing or intermittent
Your cadence sensor was not picked-up by PP during the pairing process.
Ride your bike for 10 seconds, stop, then do a new pairing. Then, your cadence sensor should work. This may fix your HR strap problem too.
Your ride looks great as-is; you are within 1W of your DFPM.
