Happy New User with Questions.
Manjimobx7
Post by Manjimobx7 »
Hi, having received my PP on Friday I have successfully set it up and did two rides on Saturday and (predictably I guess) have a couple of questions.
1. I seemed to get 0 watts showing when pedaling on downhill sections. Is this a matter of adjusting smoothing?
2. I purchased the combo mount but it seems to me there is no adjustment for the angle of the mount that allows me to tilt my Garmin up whilst keeping the PP level - is this correct?
3. My speed/cadence sensor is located level with the chain stay not above nor below (Giant Ridesense) but there is no option for this in the settings - any suggestions?
I’ve attached the two ride files in the hope that you may be able to assess them to see if there are any parameters that should be altered.
I found the set up process simple - thanks :)
iBike_02_28_2016_0613_32_km_HiDef.ibr
(669.41 KiB) Downloaded 309 times
iBike_02_28_2016_0001_41_km_HiDef.ibr
(765.79 KiB) Downloaded 304 times
Cheers,
Andy
SW Western Australia
