I was checking a ride file in Isaac and noticed the "View DFPM" button was available.
What is curious is that during the ride I kept getting a DFPM failed noticed. I double checked that the DFPM was off in the setup, and it was off.
I was riding with a friend who has a Vector2 PM. Just about everyone I ride with on the team has a PM and I have never seen this before.
Any ideas?
DFPM readings when none attached
- iBike_07_03_2016_1021_51_km_HiDef.ibr
- (1.55 MiB) Downloaded 1024 times
Re: DFPM readings when none attached
Somehow, your unit was paired when there was a DFPM in the neighborhood. You picked up its ID.
This is an easy thing to fix.
Connect your unit to Isaac, then go to "Edit/Edit Profiles..."
Click the "Forget DFPM" button.
Then click the "Send to Device" button.
This will solve your problem.
- Screen Shot 2016-07-05 at 9.37.35 PM.png (284.93 KiB) Viewed 35084 times
Thanks John.
(Do you ever sleep?)
Is there a way to repair the file? In this case, it's not important.
Thanks again.
Thanks again.
Yes, in 5 minutesblp wrote:Thanks John.
Don't click the "View DFPM" boxblp wrote:Is there a way to repair the file? In this case, it's not important.
Thanks again.
It looks like you were riding with the person who had the DFPM.
Exactly, I was riding with someone with a DFPM. Kinda creeped him out when I told him I knew how much power he was producing. Might become my secret weapon
