Pout enabled or not?
Zoltan
Post by Zoltan »
I surmised that after upgrading to Fw5 including GT key feature, the small 'bulb' next to 'pout enabled' in Edit profiles menu item will be light green to show that power output is enabled. When I had a Gen3 iAero I did have the light green bulb.
Alas so far I have had no chance to test with my Edge 705 whether it identifies my Newton as a power meter sensor, but I am afraid it will not.
May I be relaxed that the bulb next to 'pout enabled' means nothing in case of a Newton 5 device?
Re: Pout enabled or not?
Do a scan with your Newton 5, then Pout should be enabled.
Zoltan
Post by Zoltan »
Thanks, I'll do.
EDIT: Today I tested it, and voila, it works.
