John,
Thanks for activating my account.
Here is my first lazy/easy/short ride after the calibration ride for my new PowerPod. Just wanted to see if it looked normal. The only thing I did was set up my profile and change the power smoothing from Dynamic to zero seconds.
How does it look?
Simple question... Do I need to somehow turn off the PowerPod or does it just go to sleep like the other ANT+ sensors do?
Newbie PowerPod User First Ride
- iBike_06_28_2016_1956_4_Miles.ibr
- (64.29 KiB) Downloaded 334 times
Re: Newbie PowerPod User First Ride
Your first ride looks great! There are a few seconds at the beginning of the first ride where PP settles into a normal mode. You can edit this out using the File/Split File at Cursor" command.
PP will go to sleep automatically after 20 minutes of inactivity.
John,
Thanks for taking a look. Since I have never used a DFPM, I have nothing to compare with but it sure looks reasonable to me the PP is working as expected.
The more I play with the Isaac software, the more I realize how powerful it is and how much of a dream it is for a tech geek engineer like myself.
I just realized I could merge the data from my Edge 520 and get a GPS map to go along with my ride file. Very cool! Makes geeking out over the data even more fun!
The ability to tweak settings and have them apply to an existing ride file is freaking awesome!
There's a lot of cool stuff buried in Isaac, and it is definitely worth exploring all the interesting things you can learn through it.
Have fun!
Have fun!
