Profile 2 - Out front mount
Bugsbunny
Post by Bugsbunny »
Hi John
I have a question on how to be *sure* that I have correctly set the profile to #2 - to reflect the usage of the out-front mount.
Background
Like most people, I started with the standard handlebar mount. That worked fine. But later, I bought an out front mount (Fouriers branded). It is not made of plastic so should not cause any "bounce" issues. So my profile was originally #1 with my weight and bike details inputted accordingly.
Now with the new front mount, I need to change it to profile 2. I have since deleted all profiles and "started again" and have now just one profile under profile #2. However, within ISAAC, I sometimes get confused with the user interface to know whether or not my profile is correctly set to profile 2 AND that profile 2 is correctly interpreting it to be using an out front mount. From memory, within ISAAC it appears my profile 2 is somehow listed in the list as profile 1 at the steps when I "send profile to..."
Is there some way to just make sure I get this step 100% locked in so that I can then work on the fine tuning of the calibration (I'll put that in another topic). That is, I need a way to identify that my profile is indeed set to profile 2. I use ISAAC for MAC btw.
Bugs
Re: Profile 2 - Out front mount
Connect PowerPod to Isaac
Go to Edit/Edit Profiles
In the Basic tab, click the drop-down menu item next to *Set Active Profile in Device"
Screen Shot 2016-06-16 at 9.52.38 AM.png (147.42 KiB) Viewed 2537 times
Select profile 2
You will get a confirming message
Screen Shot 2016-06-16 at 9.54.09 AM.png (340.94 KiB) Viewed 2537 times
Do whatever changes you want, then click "Send to Device" to update your Profile 2
