newton on rain
bruno.oli
newton on rain
Post by bruno.oli »
i had a 4 day race, and 3 of those days were under rain almost of the time. so my newton was crazy lolol ! i was climbing 4000watts :lol:
is there any thing i can do, to prevent this?
Re: newton on rain
Please post your ride file. Also, please post photos of the front of your Newton and also the bottom (where the USB port is).
bruno.oli
Re: newton on rain
Post by bruno.oli »
here are the files
iBike_06_12_2016_0959_61_km.ibr
(927.59 KiB) Downloaded 581 times
iBike_06_11_2016_1108_104_km.ibr
(1.18 MiB) Downloaded 626 times
iBike_06_10_2016_1058_55_km.ibr
(674.86 KiB) Downloaded 618 times
bruno.oli
Re: newton on rain
Post by bruno.oli »
i only have this one today, the bike is on the way home .only in 2 or 3 days i can take pictures
Re: newton on rain
Sorry, I meant the Newton itself, not the mount. Front and bottom photos
bruno.oli
Re: newton on rain
Post by bruno.oli »
i don´t have now a picture of the front
Re: newton on rain
You have one of the original Newton models. If you do a lot of riding in rainy conditions you should upgrade to Newton 6.
http://www.ibikesports.com/product/newt ... y-upgrade/
bruno.oli
Re: newton on rain
Post by bruno.oli »
i was racing, couldn´t choose.
i have read in the past, that ibike newton worked in the rain.
just a sugestion, put in the an option on issac to export files without watts. i´m having a lot of trouble doing it.
i whant to calculate HR - TSS IF in wko4
Re: newton on rain
Post by Russ »
Bruno,
I upgraded my newton to the Newton 6 (it is a body upgrade for a Newton 5 - if you have that). Otherwise the best technical solution for older Newtons is the 'remote wind sensor' which is a hose with collection horn and a back end plug to fit the wind port.
This will block rain from being able to clog the wind port. I had one on my old Newton, worked in the rain.
The Newton 6 body upgrade has also made a non-issue for me. The older Newtons did have some weakness in heavy rain.
There is a repair ride file for blocked wind sensor feature in Isaac you can use too.
Hope this helps,
bruno.oli
Re: newton on rain
Post by bruno.oli »
made it diferent. newton is a great tool to start using with watts, i love it. but i got so depedent in the watts that when it did not work, the race whent very wrong...
