new powerpod, no wind/elevation values, low wattage
i just got my powerpod and Garmin 520. Today i did 2 short rides for calibration purposes and to see if all sensors work properly. But… i think a have a problem.
The power readings are fairly low, too low.
As far as i understand it. wind readings of „0“ and Elevation „0“ are suspect? And for a circular ride only a tail wind is mentioned not a head wind?
Another thing. Every now and then the red powerpod led is on, while the bike is stationary for hours, one click of the button and the red led flashes another click led is off.
Please could somebody take a look at my ride data and tell me if and where i might have a configuration problem.
Alex
Alex
- iBike_04_16_2016_1028_7_km.ibr
- short ride right after calibration ( yellow light )
- (31.25 KiB) Downloaded 446 times
Re: new powerpod, no wind/elevation values, low wattage
here a view of the mounted powerpod.
thumb screw is tightened and no rotation of the powerpod
- handlebar mount
- IMG_2152.JPG (192.76 KiB) Viewed 9910 times
speedracer
I had similar issue bcs. of a too low value for the wind scaling value. Have a look into your profile and check the value. In my case it was by deault always put to 1.000 which is way too low.alex77 wrote:As far as i understand it. wind readings of „0“ and Elevation „0“ are suspect? And for a circular ride only a tail wind is mentioned not a head wind?
There is no wind reading and your elevation is dead flat--both are problems.
Press-hold the PowerPod button for 10 seconds or so, until it goes out briefly and then starts flashing again. This does a hard reset of the device.
Hopefully the hard reset will fix things.
Then, go out for a ride and post your ride file.
If you still don't have wind and elevation readings please contact technicalsupport@velocomp.com
thanks for quick reply (on a saturday no less). i went for short ride for the third time today
. But unfortunately without much success.
...did the mentioned "hard reset" twice!?
1. did hard reset : push + hold button for 10+ seconds till red light flashes
2. pairing of speed sensor + pairing garmin 520
3. start calibration ride BUT no flashing yellow light!!! .... rinse & repeat
1. & 2. & 3. But again no yellow light!!! no count up to 100 in the power display of the garmin
went for a short quick(ish) ride, with considerable headwind here in Northern Germany today ( if this info helps )
the resulting ride file :
- iBike_02_28_2016_0001_12_km.ibr
- ride after hard reset
- (51.65 KiB) Downloaded 348 times
OK, let's try one final thing...
1) connect your PowerPod to Isaac
2) Go to "Device/Setup/Reset Profile-Device..."
3) Click the "Reset Profile 1" button
4) Disconnect your PP from Isaac, wait for the light to go out
5) Click the PP button. It should show solid red (if it does not, stop here...)
6) After showing solid red, press-hold button for 4 seconds to pair to your sensors
7) Light should show solid yellow.
8) do a 5 minute ride (1W-->100W), then a short ride thereafter
9) Post the two ride files
I'm suspecting that your PP needs replacement, but this will definitely tell the story.
Sorry for the hassle...
ok, here we go...
1) done
2) and 3) first try (com error) second try done
4) disconnected but during steps 1-4 no solid light on
5) clicking PP button : flashing red light ( 9 times )
i am stopping here...
(edit: as i am writing this post... the solid red light comes on and stays on .....)
an email with my problem was sent previously to technicalsupport@velocomp.com
and it's no hassle, i really want to get this pp working properly.
and know what? should i contact the vendor directly?
1) done
OK, if you got the light to go solid red, that is a good thing...
Pair your PP to your sensors (press-hold for 4 seconds). Light should then become solid yellow.
If that works, then do the 5 minute ride. Power should go from 1-->100W.
Then, ride for another 5 minutes.
Post ride files. If you still have no elevation change and no wind then you've got a bum unit.
Let us know!!
Let us know!!
one last try.
1.) charged the powerpod till „Light off fully charged“
2.) re-mounted powerpod to handlebar
3.) after waking up / hard reset? repairing of speed sensor and Garmin Edge 520
4.) begin ride. FLASHING YELLOW LIGHT and Garmin indicates count up to 100.
5.) after reaching 100, NO SOLID YELLOW LIGHT, but LIGHT OFF completely
6.) clicking button: NO GREEN Light, only a few flashes of RED LIGHT. after that NO LIGHT at all
during ride
7.) continue ride for 10 minutes with varying effort and speed, Garmin displays wattage between 80-90w declining to 48-50w
8.) unmount powerpod and connect to ISAAC, download ride file(s). Pop up windows with message „ride recorded with factory default…“
9.) wind and elevation values/readings missing.
further observations:
- erratic behaviour of der RED LIGHT when powerpod is not in use. Static powerpod, unmounted from bike, on desk… RED LIGHT comes on suddenly, click of button results in a few RED LIGHT flashes and then LIGHT OFF
- after all the hard resets, various calibration rides and sensor (re)pairings, never saw SOLID YELLOW Light
- never saw SOLID GREEN LIGHT ( only directly after pairing of sensors ) or FLASHING GREEN LIGHT "when starting ride"
I am at a loss
one last try.
during ride
I am at a loss
- iBike_02_28_2016_0001_2_km.ibr
- calibration ride
- (11.22 KiB) Downloaded 378 times
ride file directly after initial calibration
- iBike_02_28_2016_0006_5_km.ibr
- (20.69 KiB) Downloaded 349 times
You are a good sport for doing all this...
Unfortunately your unit is not working.
Please send shipping information to technicalsupport@velocomp.com and we will get you a replacement unit.
hello,
got your replacement unit in the mail today. calibration ride done right away
right out of the box mounted on the bike .....
does it now look as it should be?
regards
Alex
regards
Alex
- iBike_01_17_2016_2039_5_km_HiDef.ibr
- (87.36 KiB) Downloaded 420 times
Hello,
i am sorry to say, while the replacement seems to be working correctly on the bike ( i just got done my initial FTP test ride) , the USB connection is spotty and the USB connector is dying on me. i tried various different usb cables i had within my reach, but....
what know? another replacement?
i am very dissapointed
Alex
Alex
