Moving Profiles for the powerpod in Issac
nicholp1
Post by nicholp1 »
John
I need a bit of help, I am about to setup another bike profile (with a out front type mount) and I understand that should be on profile #2. I realized that I had been using a bike with bar mount on profile #2 and hence I would like to understand how best to move profile #2 to #3 in Issac. After moving profile #2 to #3 I'm guessing I would delete #2 and then set up the new bike as normal on #2.
Could you give me a some guidance on moving the profiles
Many thanks in advance.
Re: Moving Profiles for the powerpod in Issac
Do the following:
1) Connect your PP to Isaac
2) Go to Edit/Edit Profiles/Set Active Profile/Profile 2
3) Click "Extract From Device". This will copy your profile 2 into Isaac.
4) In Edit Profiles, Set Active Profile to Profile 3
5) Click "Send to iBike". This will copy your Profile 2 into Profile 3.
6) Import the attached profile using Edit Profiles/Import...
7) Set your Active profile to Profile 2
8) Click "Send to iBike". This will put the factory profile for Profile 2 into your PowerPod
9) Your PP is now set to Profile 2. Do a pairing and 5 minute ride and you'll have profile 2 for your front mount and profile 3 for your other bike.
Profile 2.ibp
(446 Bytes) Downloaded 248 times
nicholp1
Post by nicholp1 »
Many thanks for the super fast reply.
