Using The Newton+ For Yourself.
kensisti
Post by kensisti »
Newton+ and Isaac are awesome tools for training. I set up low cadence and speed on my magnetic trainer to match a climb I frequent. Then modified the power coefficients off a generic trainer setting in the trainer list to match the power and speed on the climb. I saved the modified setting as "hill repeat". And I do hill repeat intervals that match the actual climb on my trainer. What more could you ask for from a device and software?. To boot my Cat Eye CS 1000 trainer is not on the trainer list. However it is still use full as I described above. Awesome set up Velocomp. If only there was a pill I could get for instant cycling gratification....NOT!
Re: Using The Newton+ For Yourself.
Thank you for the kind comments!
