stages pm with newton
ianusy2k2
Post by ianusy2k2 »
Is stages compatible with Newton?
Re: stages pm with newton
Yes; Newton will read Stages power readings
ianusy2k2
Post by ianusy2k2 »
Doing a scan of Ant sensors will automatically detect the DFPM? How will you know if Newton is showing the DFPM values? I'm trying to switch DFPM display on/off by following the manual
Yes, doing a Scan of ANT+ sensors will automatically find the Stages (or other) DFPM.
After a Scan, by default the Newton displays the DFPM readings ("On dFP diSP"--DFPM display is on). If you prefer to display the Newton power readings on your screen, then enter Setup (press-hold the center button until "setup" appears). Click the down arrow until "On dFP diSP" appears. Click the center button. "On" flashes. Use the bottom arrow to select flashing "Off dFP diSP". Click the center button to accept' "done" flashes. Press-hold the up arrow to exit setup.
ianusy2k2
Post by ianusy2k2 »
Thanks for the reply... One last question... Do I need to do calibration again
No recalibration of your Newton is required.
