During my ride today, noticed a sudden change/loss of power about halfway. It's a misty morning. I just let it go hoping the computer will correct itself. About 7 miles before home, I finally can't help it so I stopped and checked the "set up". Wind Cal was VERY HIGH. Blew air in the port to blow out any blockage if any and then click Wind Cal to reset to zero. But every time i click, the number stay high or sometimes negative. I then did a trip reset and did the same. "wind cal" numbers stayed high. I merged the 2 files together.
Wind cal changed in middle of the ride
still-chasing
- iBike_02_13_2016_0647_53_Miles.ibr
- 2 files merged
- (529.46 KiB) Downloaded 462 times
still-chasing
Re: Wind cal changed in middle of the ride
How do I repair the bad file I mentioned above. Thanks!
It looks like the mist blocked your wind sensor. If you ride often in these conditions it's time to upgrade to a Newton 6!!
I used the Tools/Repair Selection for Blocked Wind Sensor... command to get your file back to normal. Highlight the bad wind data then apply the command.
Repaired ride file is attached.
- Screen Shot 2016-02-16 at 5.26.37 PM.png (511.95 KiB) Viewed 5469 times
- iBike_repaired_02_13_2016_0647_53_Miles.ibr
- (543 KiB) Downloaded 424 times
still-chasing
Thank you.
