I feel like I am totally missing the "merge" command in the software, but I can't figure it out for the life of me. I have a ride from my Garmin and I would like to merge the GPS info into the software. I have opened my ride from my PowerPod into Isaac already.
Merging ride in Isaac
Re: Merging ride in Isaac
Put your Garmin file into a .gpx format, then use the Issac command below.
- Screen Shot 2016-01-18 at 9.42.03 AM.png (168.19 KiB) Viewed 7079 times
I don't seem to have that option?
- Capture.JPG (26.63 KiB) Viewed 7076 times
You are running Basic Menus in Isaac.
Do View->Menus->Advanced and then check the File Menu. Should now be there.
@Velocomp: When I select the GPS tab (instead of Peaks) for an activity without merged gps, it would be nice if it did an implicit Ctrl-M (Merge GPS). Instead it gives an ad for the Tracker App. This could be a configurable advanced option.
Notedtexmurphy wrote:You are running Basic Menus in Isaac.
Yes, you want your Garmin file in .gpx format. I have never got a .tcx file to merge.
'05 Bianchi Axis custom build
