Power output zero or intermittent/ other issues
ianusy2k2
Post by ianusy2k2 »
Have some issues with Ibike Newton 5... power is zero or low... ive checked the sensors and placed them correctly... on acsents power seems to be right... on flat roads or descents... power seems to progressively low until zero... ive used another speed cadence sensor.... still the same problem.... what seems to be the problem? im one of the few who uses Ibike here in the philippines.... One more problem... when doing Cal ride... its always Cal ride error see ISAAC... i followed instructions to the letter....
ianusy2k2
Re: Power output zero or intermittent/ other issues
Post by ianusy2k2 »
when you accelerate there is a power output and then the readings gradually goes down to zero....
Please post a ride file that illustrates your problem.
ianusy2k2
Post by ianusy2k2 »
here are my last few rides
iBike_07_28_2015_1030_0_km.ibr
Cal Ride but failed
(40.05 KiB) Downloaded 385 times
iBike_07_25_2015_0556_118_km.ibr
(627.13 KiB) Downloaded 393 times
iBike_07_28_2015_0046_1_km.ibr
(7.56 KiB) Downloaded 389 times
Something is wrong with your wind sensor. Please contact Tom Gore at tgore@velocomp.com for technical support. We likely will need to provide a warranty unit.
ianusy2k2
Post by ianusy2k2 »
OMG... that will be a big problem... Im currently in the Philippines....
ianusy2k2
Post by ianusy2k2 »
John i went for a rainy ride last Sunday.... and i rode again today... seems the power output is back to normal... attached is my last 2 rides
iBike_08_09_2015_0629_153_km.ibr
(888.3 KiB) Downloaded 391 times
