Found New Ids
Found New Ids
Just about everytime I download a ride file Isaac gives me a message to the effect "Found new Device IDs, do you want to save?". But I use the same bikes with the same spd/cdance sensors all the time, so I don't understand why I'm seeing this message. Happens 75% of the time.
Re: Found New Ids
This message means that the profile stored in Isaac has different wireless IDs than the profile currently used by the Newton.
When you see this message if you update (save) the wireless IDs in your Isaac profile then the message should go away.
Re: Found New Ids
I save it everytime but it keeps coming back, over 50% of downloads flash this message. No change in profile, hardware, anything between rides.
Re: Found New Ids
Hmm...what version FW are you using? What version of Isaac? Please post your profile from Isaac, as well as a recent ride file.
Re: Found New Ids
Here are a recent ride and a profile for that ride, and one which frequently gives me the message about finding new IDs, although I can't remember if this particular ride asked that question.
In another thread I had asked about a HR strap problem I was having, I'm wondering if these two issues are related. Since the HR strap was probably only sending intermittent signals perhaps the found new ID message had to do with it, not the spd/cad sensor.
FW 5.08
Isaac 3.0.3
FW 5.08
Isaac 3.0.3
- iBike_06_20_2015_0810_61_Miles.ibr
- (1.07 MiB) Downloaded 365 times
- BA profile.ibp
- (382 Bytes) Downloaded 378 times
