Newton Tracker sync problem
amet
Post by amet »
Not for the first time (it happened twice before) there was a sync problem after the ride I did today.
It seems to me that this is a (temporary ?) server problem, but I have not all day to keep trying to sync the ride...
I don't mind to pay for something, but it has to work!
Re: Newton Tracker sync problem
What, specifically, was the problem?
I did a ride yesterday and had no problem with the sync.
amet
Post by amet »
Well, the app refused to sync a finished ride and, as I wrote, not for the first time. I tried about 10 times (close the app and restart it) and than gave up.
Today I did a new ride (yesterday was a rest day) and, as was the case the other times, when I started the app it synced the previous ride without any problem. So I am pretty sure it must be a server problem. I didn't change my settings or anything, just tried to sync a ride after stopping it.
Please send an email to technicalsupport@velocomp.com. We will investigate further.
ronpei
Post by ronpei »
similar issue yesterday June 16. The annoying issue is when I start up Tracker because there is a ride that was not synced it tries to sync and takes forever (meaning at least a minute) until it fails. For some reason the upload will not work now going on to the second day. Even when I do a simple start and stop ride (which would work in past to get it to upload). Any ideas?
Hmm..I have not seen this issue before.
Are you using the iOS or Android version?
I would try three things:
1) Quit the Tracker app and relaunch it. See if that fixes things
2) Reboot your phone. See if that fixes things
3) If both of those fail, then delete the ride file that does not sync.
amet
Post by amet »
Indeed, yesterday the issue reoccurred (for the first time since May 10).
I have sent a mail to technicalsupport@velocomp.com.
I'm using Android and I have tried suggestions 1) and 2). No use.
I don't understand suggestion 3). How can I delete a ride in the Newton Tracker app, since there is no list?
In the past the ride synced without any problem the next day. I cannot explain why. I don't know about yesterdays ride, since today I didn't yet start another.
I just checked and there may be a problem with our server, causing rides not to upload.
It may take us a day to fix the problem; hang in there!
lavoww
Post by lavoww »
I'm having the same problem. Did a ride last night, 6/16/15, and it is still trying to sync. Can I do a ride using the app and expect that multiple files will be uploaded once the server is back in action?
ronpei
Post by ronpei »
in my case it is android app. Also as per last question, if I ride multiple rides that are not uploaded is there a limit that can be stored or is it device memory limited?
amet
Post by amet »
Velocomp wrote:I just checked and there may be a problem with our server, causing rides not to upload.
My first post:
amet wrote:Not for the first time (it happened twice before) there was a sync problem after the ride I did today.
It seems to me that this is a (temporary ?) server problem, ...
The rest of my post may have been a bit negative, but I wasn't that wrong after all.
For your information. I did another ride today and this time the problem persists. The previous ride did not sync, and the one I did today caused the same problem. But I suppose you are aware of that.
I hope that you will be able to solve the problem soon.
It looks like the NT server is back in business. We had to restore the database of NT users from a backup done on Sunday, probably around 3 AM EDT.
iPhone users can re-attempt to upload rides using the iPhone app. Android users can attempt to re-upload missing files by launching the Android app, starting a ride, then ending the ride after a few moments.
Note that if you created an NT account via Isaac since Sunday you will have to create a new account.
amet
Post by amet »
The problem seems to have been solved indeed.
I did a ride yesterday afternoon (June 18 CET) and it took a while, but the ride uploaded without a problem.
The time it took may have two reasons:
1. Several files had to be uploaded (3 since Sunday);
2. The data connection was not so good from where I was.
Anyway, thanks for solving the issue. And I'm aware of the fact that when ICT is concerned, problems may occur.
amet
Post by amet »
Come on! Your server is down again and I'm unable to upload my data.
Reliability is dropping fast now.
Yep, it's down, and the guy who maintains it is on vacation. We will let you know when it is fixed.
In the mean time, continue to record your NT rides on your app. Once things are fixed everything will be able to be uploaded and recovered.
lavoww
Post by lavoww »
I'm having the same problem, unable to sync. Is the server off line or down for some reason? I'd like to sync my race files and send off to Training Peaks. Please help.
lavoww wrote:I'm having the same problem, unable to sync. Is the server off line or down for some reason? I'd like to sync my race files and send off to Training Peaks. Please help.
I repeat my post of earlier today: the NT server is DOWN. Our specialist is on vacation and won't be able to fix the server until returning on July 7.
Continue to use the NT app to record your rides. Once the NT server is back up you will be able to upload your NT data and sync it to your ride files.
We apologize for any inconvenience.
jon
Post by jon »
I have just started to have this problem. It was working great but now I can not connect. Nor can I connect from my desktop - are you having server problems again?
This is the same server problem that we reported a few days ago. It won't be fixed until our guy returns from vacation on July 7.
Continue to record your rides with NT and you can sync your files once the server is repaired.
mxfarm
Post by mxfarm »
At risk of beating a dead horse, is this the same issue why I can't upload from Isaac to Training Peaks?
Marc
Yes, it is the same issue.
mxfarm
Post by mxfarm »
Thank you John.
marc
redhybrid
Post by redhybrid »
I cant connect to Newton Tracker yesterday and today, enclosed are the photo from my Android cell phone and my PC... :cry:
Newton Tracker app (after 80km ride)
Isaac newton on PC
Isaac newton on PC
Yes, that is what this entire thread is about...
We hope to have the server working again in a few days.
bruno.oli
Post by bruno.oli »
i will sugest that newton tracker in the future would have a option to save the track in to the phone. so we could download it manualy to isaac.
i have experence this problem 3 or 4 times in the past.
bruno.oli wrote:i will sugest that newton tracker in the future would have a option to save the track in to the phone. so we could download it manualy to isaac.
That's exactly the way it works. The trick is getting the GPS data into Isaac. Isaac communicates with the server to accomplish this.
I know this has been a long outage and I apologize, but please remember that this has happened only once in the past 3 years. Once our guy returns from vacation (today?) we will not only fix this problem but take measures to ensure it does not happen again.
Newton Tracker server is fixed
NT server is up and operating!
iOS users: touch "MyRides" in the NT app, touch the ride you want to upload, then touch the Isaac button. Do this for each ride.
Android users: do a short ride, then touch "Done". All of your rides will upload.
After uploading your NT data, in Isaac open the ride you want to add GPS data to, then use the command "Device/Newton Tracker Get GPS Data...". Your GPS data will be added. Click the "Save" icon to permanently add GPS data to your ride file.
We apologize for the long wait to get this fixed!
bruno.oli
Post by bruno.oli »
hello,
i have a problem, and i think it is in my android phone/newton tracker.
all goes good during the ride.
when i upload from the newton to issac software, then it downloads automatically the file from the newton tracker, but it haves it gives me a problem because of the hour.there is a diference between newton and newton tracker of 1 hour.
so issac changes the start of the ride, 1 hour less to sync right
* i live in azores
bruno.oli wrote:hello,
* i live in azores
Each time you connect your Newton to your computer, your Newton's time is automatically set to the computer time.
Look at the time that your phone shows, and also look at the time your computer shows. They are different by one hour, and one of them is wrong.
amet
Post by amet »
Tell me that the server isn't down again. I cannot sync the ride I just did.
