Large difference in readings Newton to Powertap
smeagolsmy
Hi, I did a ride yesterday, and on looking at the ride file, noticed a big difference between the Newton figures, and the Powertap figures, can you spot any reason why? I will check the calibration of the Powertap next ride, but the ave power figure for the ride from the Newton at 117w seems pretty low?
- iBike_05_02_2015_0753_70_Miles.ibr
- (1.19 MiB) Downloaded 641 times
Re: Large difference in readings Newton to Powertap
Nice ride!
Looks like your wind sensor became blocked; notice the severe "icicles" between hour 1 and 4:30. Rain?
I fixed this with Tools/Repair ride for blocked wind sensor.
Also: either your PT is off or your Newton settings are wrong. I fixed the profile so they would be close for this ride; you should check with another ride after you're sure your PT is properly calibrated...
- iBike_05_02_2015_0753_70_Miles_JRH.ibr
- (1.27 MiB) Downloaded 625 times
- SmeagolJRH.ibp
- (424 Bytes) Downloaded 575 times
