Hi
I moved my newton across to a new bike and seem to be having trouble calibrating it. It's definitely reading higher power than I can produce, maybe 60-80% higher than it should.
I've tried all the normal things, cal ride, cal tilt, cal wind, even a different mount.
Attached is a ride file from a out and back ride. Any Ideas?
New Bike Config Problem
- iBike_2015_04_18_0932_30_km.ibr
- (392.36 KiB) Downloaded 437 times
Re: New Bike Config Problem
Somehow your Crr was adjusted upwards from 0.0054 (normal road) to 0.035...(quicksand).
I put your Crr back to a normal level. Load this profile into your Newton and all will be well.
- JRH_Litespeed.ibp
- corrected profile
- (1.15 KiB) Downloaded 424 times
- iBike_JRH_2015_04_18_0932_30_km.ibr
- corrected ride file
- (392.1 KiB) Downloaded 389 times
- Corrected ride stats
- Screen Shot 2015-04-22 at 9.52.58 PM.png (533.37 KiB) Viewed 6401 times
- Quicksand ride stats
- Screen Shot 2015-04-22 at 9.52.22 PM.png (538.9 KiB) Viewed 6401 times
Thanks I'll give that a try
Thanks for your help.
I've used the updated profile and I still seem to have the problem (350-500w being displayed on the flat @32-36kph).
This weekend I did two solo largely out and back rides in low wind and Issac doesn't recommend any significant change.
I've attached the ride files. Any ideas?
Thanks again
Thanks again
- iBike_2015_05_03_1547_32_km.ibr
- (271.29 KiB) Downloaded 390 times
- iBike_2015_05_02_1622_27_km.ibr
- (247.4 KiB) Downloaded 436 times
I'm not sure how it happened but the rides you have show a Crr of 0.03. That would be like riding through quicksand...
Returning your rides to a "normal" road resistance of 0.0054 returns your rides to reality.
I would do a new cal ride.
- iBike_2015_05_02_1622_27_km_JRH.ibr
- (263.16 KiB) Downloaded 429 times
- iBike_2015_05_03_1547_32_km_JRH.ibr
- (289.21 KiB) Downloaded 395 times
