DFPM
JoseJ
DFPM
Post by JoseJ »
Hello..if I pair a DFPM..to my newton...and the settings are turned on....... the meassurements in the screen are supossed to be de ones from de DFPM...not from the newton... but the NP..IF and TSS factors that newton shows..will these factors also come from the DFPM?
When downloading to isaac..will I see both measurements..DFPM and newton?
Thank you
Re: DFPM
If you have the DFPM on, then TSS etc will be calculated from the DFPM measurements.
Yes, you can see both measurements in Isaac. Check the View DFPM box to see DFPM measurements.
JoseJ
Re: DFPM
Post by JoseJ »
I have paired a DFPM..stages ...dfpm settings are on...the device is correctly paired as far as i know ..but power in the screen is 0...power and cadence are on and off....but most of the time..power fails and cadence as well
the DFPM is working well because my garmin unit reads all the measurements with no problem at all.
what should I do?
thank you and Merry Christmas.
Re: DFPM
If cadence is zero then power will be zero too.
You need to get a solid cadence reading before checking anything else...
