Hello lately I have ugraded to Newton 5, since then It is hard to hold my watts, the harder I push the lower even with ftp intervals, it seems to me that the device shows low and low watts. May be I did something wrong with my cal ride.
Could please somebody help me to set it?I am attaching my last ride
Something else when I whant to change my profile manually the screen shows something like this -------W
And I can not change my profile
Thank you very much
Loww Low outputs
Re: Loww Low outputs
I am correcting the ride with Isaac and when entereing the right altitude the watts go right as they should be.
So. Is it adviseble to enter current altitude prior to a ride?
Thank you
Thank you
It looks like your profile is "off".
Load the attached profile into your Newton and see if this improves things.
- Orca_JRH.ibp
- (543 Bytes) Downloaded 765 times
Yes...now it works great...i have even higher watts than ever before
did the changes you made afect the profile 2 as well?
thank you John
thank you John
No, the changes affect only the profile that is used. Each profile needs to be changed individually.JoseJ wrote:Yes...now it works great...i have even higher watts than ever before
thank you John
