I'm getting the "Labview: Memory is Full" message still. It seems to happen after a 0km ride ends up on the Newton. This usually occurs after a ride in the rain. Anyway, is there a fix in the works? Just wondering if it's a Newton or an Isaac thing.
I'm attaching 2 screenshots of the messages that appear.
Labview: Memory is full (REVISITED)
andrewlees
Screen Shot 2014-09-22 at 7.28.08 AM.pdf- (400.8 KiB) Downloaded 386 times
Screen Shot 2014-09-22 at 7.28.02 AM.pdf- (396.04 KiB) Downloaded 350 times
andrewlees
Re: Labview: Memory is full (REVISITED)
Seems that no one at Velocomp is caring too much about this issue. Hopefully the new update to Isaac will help.
Sorry, we've been a bit overwhelmed with the Newton 5 release.andrewlees wrote:I'm getting the "Labview: Memory is Full" message still. It seems to happen after a 0km ride ends up on the Newton. This usually occurs after a ride in the rain. Anyway, is there a fix in the works? Just wondering if it's a Newton or an Isaac thing.
I would suggest you erase your ride memory and see if that fixes the issue. The likely problem is that something in your Newton ride memory has been corrupted.
