Newton Locked up!
Rico
Newton Locked up!
Post by Rico »
I uploaded some ride files this morning. Then I hit one of the buttons and some how the display showed the words "End Train" It continues to display this! I have tried to reset the Newton holding the the center button with the bottom three buttons but it seems stuck!! In this state the display doesn't time out (Turn Off) Any Suggestions?
Rico
Re: Newton Locked up!
No worries.
For a hard reset simultaneously press the left, bottom, right, and center buttons.
The display will go blank. Release the buttons and the unit should reboot normally.
Rico
Post by Rico »
I did try a hard reset earlier but the Newton would not reset. So after you mentioned to do a Hard reset in your reply, I decided to try it the reset again. Lo and behold it worked!
Rick
Connect your Newton to Isaac to update the date/time.
