Cal ride does not work
vktr
Post by vktr »
Hello! Every time I do a cal ride with my iBike newton it says "cal ride done" but after a few seconds it just says "cal start" again, as if i never did the cal ride. I thought it was something wrong with my device but when I got home and looked at the ride file it looked fine (I think).
iBike_04_09_2014_1516_3_Miles_CalRide.ibr
(46.74 KiB) Downloaded 326 times
Re: Cal Start message shows up after cal ride
The bad news is that this is a FW bug that we need to fix.
The good news is that, until we fix the bug, there is an easy workaround for it.
1) Do your cal ride
2) If you get the "Cal Start" message afterwards [this is the bug], do a hard reset. This will eliminate the bogus Cal Start message
3) When you get home download your cal ride and use the Dial In wizard.
