can you see the high resolution data in a csv
ronpei
Post by ronpei »
is it possible to see the high resolution data in a csv or readable fashion? It looks to me that when you download a hi res ride to csv it is not at the high resolution data rate.
Re: can you see the high resolution data in a csv
We report csv data only in the 1 second rate.
ronpei
Post by ronpei »
so then there is no way to see the fine detail at 16 points/ second then?
ronpei wrote:so then there is no way to see the fine detail at 16 points/ second then?
Correct
