Cal Rides and PowerStroke
texmurphy
Post by texmurphy »
Should Cal and CalCheck Rides be done with PowerStroke HighDef ON?
If PS is ON, will the Cal/CalCheck use the additional data recording to improve the calibration?
If not, would it make sense to have a HighDef calibration process option for use with PowerStroke?
Re: Cal Rides and PowerStroke
The Cal Ride is used to measure tilt offset and wind scaling factors.
Wind speed and accelerometer parameters have always been measured many times per second within the Newton firmware, so the Cal Ride factors are calculated with Hi Def accuracy.
