Another com port <-1> issue
cjonbike
Post by cjonbike »
Hi All
I have the iAero and have been using it for the past few weeks.
I use a computer that has 2 operating systems using the dual boot option.
Windows vista 64 bit
Windows XP sp3.
I have been using the ibike 2.0.6 software on the windows 64 bit system and it talks to the iAero fine there.
When I try on the XP sp3 all I get if I go into Devices/connect is the <-1> in the com port box.
I go into device manager and it shows under ports the silicon labs cp210x usb to uart bridge (com3), and is running properly. No warnings or errors. If I unplug the cable it disappears.
I have un-installed the software and the drivers and re-installed them(multiple times). No errors on install. But still no communication between computer and iAero.
I have used different USB ports.
And when I go back into vista 64 bit it works fine from all my ports.
I have upgraded the drivers for the bridge to 5.2-.2.0.
Is there anything you all see that I missed doing, or anything else I can try?
I thank you in advance for any help with this as I am stuck
Chris
Re: Another com port <-1> issue
Try forcing the com port to a different number. This has worked for other users.
cjonbike
Post by cjonbike »
To update
Thanks John so much for the reply, I did change the com ports from 4 - 32. Still no joy. I must really have something weird going on in my XP drive.
Thanks again
Chris
alback
Post by alback »
I had a similar problem with WinXP on my laptop, it eventually worked. This week-end I had to upgrade from w2k to XP on my home office computer, had the same driver problem.
I downloaded 5.2 version, it didn't work either. I came across a forum where they suggested success with driver version 4.28. I finally found version 4.28. Version 4.28 is a 2005 driver, however XP accepted the driver, then repeated the found new hardware dialogue. I re-directed it to 4.28 again and iAero worked on the original com 5 as before in w2K.
Hope this helps,
Alan
