Power Bar (PBar)--enabled in RACR mode but doesn't show up
bicyclegirl
Does anyone know why the Power Bar does not show up on the Power Screen after I definitely enabled it in RACR mode?
Re: Power Bar (PBar)--enabled in RACR mode but doesn't show up
Pbar appears only in the Power screen. Unless you're riding the bike, at rest it will look like the photo below (one dot, and the number 100 on the right, in the middle window)
- photo.JPG (85.29 KiB) Viewed 4964 times
bicyclegirl
If you have a ZUUUM meter then you must also turn the ZUUUM mode off for the power bar to display. Go to set up and look for UUU--that is the zoom mode. Scroll thru the various options until OFF appears. Press the center button to accept. Keep in mind that by turning ZUUUM off you are losing the functionality that the ZUUUM meter adds to the Newton. See this link to see what those functions are: http://zuuumcc.com/pcc/
