I am using a Newton+ and the Power In feature to log power and heart rate readings from a PowerCal. However, whilst the Newton records the data from both sources it displays the power from Power In only. Is there a way to switch between the Newton's power estimate and that of the Power In?
Mike
iBike Power vs PIN display
Re: iBike Power vs PIN display
Yes, we've just created firmware that lets the user select which power source will be recorded. We will be releasing it in the next few days.
How about posting a file with a ride done with your PowerCal? It would be interesting to see...
thanks for the reply. Just a clarification - you mentioned selecting which power source to record - I assume you mean display as it already records both which is fine.
I have uploaded a file but it is from a CycleOps SuperMagnetoPro trainer rather than on the road. If I get a chance I will do a road ride tomorrow and upload that. The PowerCal data is all over the place but when you smooth it in power meter comparison it looks quite good. It will be interesting to see how it does on the road.
Cheers,
Mike
Cheers,
Mike
- iBike_09_29_2013_1822_18_km.ibr
- (92.83 KiB) Downloaded 774 times
For reference here is a file of iBike vs PowerCal on a road ride. In the power comparison chart it looks pretty good as long as you use 2 minute smoothing! I will calibrate the PowerCal and see if it gives a closer power output and TSS.
Cheers,
Mike
Cheers,
Mike
- iBike_10_06_2013_1447_11_km.ibr
- (162.39 KiB) Downloaded 788 times
