Power2Max recorded simultaneously on the Newton
janholleman
Post by janholleman »
How can i record simultaneously on the Newton with a power2max? So that Isaac software allows detailed comparerasion of power2max and Newton+.
Now i use a Garmin 500 and use the .tcx file and then i make the comparasion in isaac.......But is it possible to record
the rides only on the ibike!!!!!!
Re: Power2Max recorded simultaneously on the Newton
The Newton+ should accept the Power2Max data as long as it is ANT+. And it sounds like it is because the Garmin 500 picks up the power2max.
So... wake up the P2M and get your CAD/SPD and HR sensors awake also. Simply press the up and down arrows at the same time and the Newton+ should find the p2m in addition to the regular sensors. That's it.
Now since the Newton plus sees PIn (power in) it will grab and store it automatically. Also the P2M data stream of power will be displayed, not the Newton+.
Upon download both the P2M and Newton+ data will be available for viewing.
janholleman
Thanks............I had tried and function perfect.
janholleman
Can you tell me why i have in calibration check the indicator in the middle
Please post the ride file and if you did an out/back after the cal ride please post that also.
janholleman
This is the Calride and thanks Fernando.....i have a few other questions but first this one :shock:
iBike_07_04_2013_1850_5_km_CalRide.ibr
(107.04 KiB) Downloaded 549 times
janholleman wrote:This is the Calride and thanks Fernando.....i have a few other questions but first this one :shock:
Check Calibration is intended for use only with regular ride files, not Cal Rides.
Your calibration is excellent (2W difference) so no profile change is required.
Needless to say, John at Velocomp is correct. Your profile is spot on. Don't even think of making a change.
