Calibration and Coast Downs can't remove selected
JamesB
Post by JamesB »
HI
I am using the Newton+ and wanted to do a new profile with aero wheels... Followed the Operating Instructions 4/23/2013 Newton FW v4.12/Issac v2.1.3)
acclimated the newton for 20 minutes, then did a 20 minute ride, then did the out and back calibration ride, I was then asked to do a manual tilt cal
I then did 7 coast downs(level road not windy, no traffic) and called it a day and went home to process the data in Issac
I think the data looks OK but 2 of the coast down values appeared to be outliers, but if I remove even one, Issac will not allow me to save the profile...
I also can't seem to process the cal ride within Issac as I am given the message
"Using cal ride calculation from unit for "setting in ibike. select Crr fixed or Crr Adjusted to analyze here"
If I select either of those options and the highlight the out and back portion, the to do that I am also not given the option to Accept and Send to ibike is grayed out again
Am I doing something wrong here???
thanks
James
iBike_05_30_2013_1848_3_Miles_CalRide.ibr
(48.08 KiB) Downloaded 436 times
130601_1734_cal_ride_AB7E1033.ibcd4m
calibration data... I think
(395.2 KiB) Downloaded 440 times
