can't open gpx or csv file for merge
RGA
Post by RGA »
Hi, I'm using Isaac for Mac version 2.1.3 and I'm trying to merge data from cyclemeter with my current ride but I get the "File format not recognized" error on both a gpx and a csv file. any thoughts? I uploaded the csv file that I tried to merge.
Also, is it possible to disable that popup when you try to open a file for merge. Seems like an unnecessary step (extra click) in the process ... File > Merge Data from Another device > pop up to confirm > select file
Cyclemeter_20130526.csv
cyclemeter csv file
(330.9 KiB) Downloaded 676 times
Keep on Pedaling,
Ray Garza
Re: can't open gpx or csv file for merge
Hmm, I've never seen this file format before. Although it has lat/lon/time I think Isaac is looking for more common file structures. What was this recorded with? Is the original file CSV or something else?
Can you export as a GPX instead of CSV??? That might do it.
RGA
Post by RGA »
This was recorded using Cyclemeter iPhone app version 9.1.3 and exported the ride as csv and gpx. I tried open the gpx version of the same ride and got the same error message, but Strava can read the same gpx file.
Keep on Pedaling,
Ray Garza
Please upload the GPX file.
RGA
Post by RGA »
Hmm, I cannot upload a gpx file to this board. Says the extension gpx is not allowed. I'll rename it and give it a .txt extension and upload it. Ok, I can't upload a .txt file either.
Keep on Pedaling,
Ray Garza
Zip or rar
RGA
Post by RGA »
good idea
Cyclemeter_20130526.gpx.zip
cyclemeter gpx zipped
(74.28 KiB) Downloaded 601 times
Keep on Pedaling,
Ray Garza
I was able to open the GPX file in SportTracks. It consisted of six separate rides that I assume were really laps. Anyways, I combined the six into one, then exported as a TCX. I can't try the merge since I don't have the original ibr file. So here's the TCX back at you. Let me know if this works.
2013-05-26_08-06-57.tcx
(1.28 MiB) Downloaded 673 times
RGA
Post by RGA »
Hey thanks Fernando, it worked fine now. I dunno how it generated laps since I didn't click on any lap button. I'll have to look at the file closer next time.
Keep on Pedaling,
Ray Garza
