newton+ won't exit from calibration...
JamesB
Post by JamesB »
Long time ibike and now Newton+ user
got a new set of wheels and decided to do a cal ride when the latest FW upgrade came out
I have tried several times and get the same result, I ride out until the I get the go back notice, then out the back leg I have to go far past the place where I started... often 3 or 4 tenths of a mile further.
Then it say says calibration complete... but a this point I am unable to exit from the set up screens and return to ibike use... I end up having to do a hard reset to return to the usual ride data display...
what is going on here?
thanks
James
SSLTTX
Re: newton+ won't exit from calibration...
Post by SSLTTX »
Newton wont exit from set up screen.
After I downloaded the new firmware 400 I had to set up a second bike and after the calibration ride the screen went directly to wind calculation.
So I went into a closed area and did a manual wind calculation and a manual calibration ride and the screen did the same thing and won't allow me to get out of set up.
JamesB wrote:Long time ibike and now Newton+ user
thanks
James
Make sure, when turning around, that you STOP prior to actually turning around (the instructions say this).
After you complete the ride, you should get a message saying Cal Done, and then the main screen should reappear automatically. If this is not happening please contact technical support.
SSLTTX wrote:Newton wont exit from set up screen.
Please contact technical support.
dtrousdale
Post by dtrousdale »
JamesB wrote:... but a this point I am unable to exit from the set up screens and return to ibike use... I end up having to do a hard reset to return to the usual ride data display...
This just happened to me. I was trying to create a new profile from scratch and after the Cal ride and the message, "Cal Done," I could not exit Calibration. Even turning the unit off and on several times made no difference. A hard reset finally did the trick. I did check my new profile immediately and did get measurements within the "official" (as posted on the Forum some time ago) guidelines for profile ranges. Would doing a hard reset give me "unreliable" numbers?
I will contact Tech Support as recommended to the previous two users.
