New Setup
dgf
New Setup
Post by dgf »
Went with new bar set up and just no way the Newton was going to see clean air without using RWS. Did some pondering and came up with this setup:
Seems decently clean, simple, should see good air. Will try Cal Ride tomorrow.
Re: New Setup
Looks good! Please post a ride file!
dgf
Re: New Setup
Post by dgf »
Seems like it works OK. Maybe a little windy for a Cal Ride but data looks OK to me...??? Attached Cal Ride and little loop I did a couple times.
Used two of these for the set up - pretty simple:
http://www.amazon.com/Profile-Design-Un ... uter+mount
iBike_04_12_2013_1712_13_Miles.ibr
(226.07 KiB) Downloaded 873 times
Cal Ride 4-12.ibr
(34.33 KiB) Downloaded 861 times
Re: New Setup
dgf wrote:Seems like it works OK. Maybe a little windy for a Cal Ride but data looks OK to me...??? Attached Cal Ride and little loop I did a couple times.
Your cal ride looks great but your 13 mile ride is odd, for two reasons:
1) your CdA is different from your Cal Ride, and is set to road-bike value. Did you change it? If so, why
2) It looks like you have strong tail winds in part of your ride. Is this correct?
