50 watt discrepancy between trainer and outside
Can someone please review my profile? I am getting approximately 50 watt difference in FTP and average watts between indoor trainer ride (fluid2) and outside. The indoor trainer is the higher.
As an example my last 26 mile loop ride averaged 104 watts but 18.4 mph - seems like wattage a bit low?
I ride a Specialized Transition LE in time trial position.
Ibike dash + power w/ remote wind sensor.
I have performed the usual suspects - calibration ride, tilt calibration etc.
Thanks in advance for the help!!
Profile:
Rider Weight: 144
Bike + Other 23
Total: 167
Tire Circumference: 700x23c (2096mm)
Aero: 0.164
Wind Scaling: .6659
CdA: .247
Crr: .0055
Friction: 1.118
Riding Tilt: 0.4%
Wind Scaling: .6659
Profile:
Rider Weight: 144
Bike + Other 23
Total: 167
Aero: 0.164
Wind Scaling: .6659
CdA: .247
Crr: .0055
Friction: 1.118
Riding Tilt: 0.4%
Wind Scaling: .6659
Re: 50 watt discrepancy between trainer and outside
Here is the outdoor ride file.
Thank you.
Thank you.
- iDash_2013_03_09_0821_27_mi.ibd
- (128.46 KiB) Downloaded 1115 times
Wow, it's almost as flat where you live as it is in Florida!toddk wrote:Here is the outdoor ride file.
Thank you.
You have a very low drag coefficient; please confirm that you are using a TT bike, and also provide your height.
Also, your ride file suggests that you are riding in the draft quite often. Is this correct?
Finally, the total weight of bike + rider is 167 pounds, suggesting that your body weight is about 144 pounds. Correct?
Given these input parameters, your Newton is reporting correct wattage for your speed and riding conditions.
Confirmed - TT bike .
Height 5ft 10.5 in
weight correct
No drafting, i ride solo... The wind #'s seem low. The weather said 12 mph winds that day , but my readout suggested otherwise
Your right , houston and florida ...very flat...and hot...and humid 8)
FWIW i'm using the ibike dash + power.
I will attach a picture of mounting - not sure if that influence #'s
Thanks in advance!
Height 5ft 10.5 in
weight correct
Thanks in advance!
mounting pics , needed place 1 in. spacer ..(not sure if this helps, just want to rule anything out)
thank you
thank you
- photo(3).JPG (44.44 KiB) Viewed 40597 times
any thoughts?
I took a look at the ride file and based on your statement that you are not drafting I would raise the wind scaling to .912. I would also suggest you do another cal ride to confirm the ride tilt of .4 as I would be inclined to think about -.1 for your size on a TT bike. However the change in riding tilt is only three watts. The big thing is the wind scaling.
Try the attached profile, it will raise your avg from 109 to 127 and should be just about right based on your info.
- toddk_mod_profile.ibp
- (481 Bytes) Downloaded 1031 times
Thanks for responding Fernando I shall give it a try!
For best results with the dash + power, should I wait till for a nearly 0 wind ? If there is wind should I ride in cross/head...does it matter?
You're using your + Power in a TT position, but without a Remote Wind Sensor.toddk wrote:mounting pics , needed place 1 in. spacer ..(not sure if this helps, just want to rule anything out)
thank you
Your problem may be that you're getting unstable wind readings because of your arms.
An RWS may take care of everything.
I actually am using an RWS. I've uploaded the latest version of firmware for + power, reinstalled and will redo a calibration ride. Not sure why it is not picking up the RWS, hopefully the latest firmware , reinstall, and new calibration ride will resolve. We shall see...
Thanks again , FWIW , really enjoying ibike it on the trainer 8) , making some nice gains in the FTP, just looking forward to getting the outdoor rides sorted.
