Scale units
EdgarCR
Scale units
Post by EdgarCR »
I download a file from my ibike and I see the correct scale units on the left side of the graphic, then I save it on my computer. But when I try to open the same file from the computer, the units change drastically. Why?
Re: Scale units
Screenshot? Example?
EdgarCR
Re: Scale units
Post by EdgarCR »
Thanks Fernando, in the upper left side the distance is incorrect, because this file is a 20' test, maybe 6 or 7 miles, the cadence is 150-350 rpm and the correct number es 80. Another thing is the HR (bpm) and the slope is something like 250% Why, thanks.
wrong scale units.jpg (113.78 KiB) Viewed 22719 times
EdgarCR
Re: Scale units
Post by EdgarCR »
This is an screenshot of the file viewed from the ibike
Re: Scale units
I guess I should have asked for the file also. Please?
EdgarCR
Re: Scale units
Post by EdgarCR »
The is an screenshot of the file opened from the ibike
from iBike.jpg (448.56 KiB) Viewed 22699 times
EdgarCR
Re: Scale units
Post by EdgarCR »
This is the file
iBike_24_02_2013_0854_11_km.csv
(21.9 KiB) Downloaded 713 times
Re: Scale units
That's an ugly file. :) But can you send the original .ibr file please? Also is this for more than one ride? When did this start happening?
EdgarCR
Re: Scale units
Post by EdgarCR »
Where can I find .ibr files? A week ago. I reinstalled the software but didn't work
EdgarCR
Re: Scale units
Post by EdgarCR »
This is for all the files in the hard disk (ibike folder)
Re: Scale units
What didn't work? If the rides are still on the iBike you could download them again. Also look under My Documents, there normally is a folder called "iBike Rides" unless you specified something different. I'm on a PC.
EdgarCR
Re: Scale units
Post by EdgarCR »
Yes, I downloaded again, when I saw the files from the ibike is ok, but the saved ones have this problem, I have the same folder in the same location and I'm in a PC too, thanks Fernando
Re: Scale units
Getting closer, you still need to post one of the saved ones.
EdgarCR
Re: Scale units
Post by EdgarCR »
This is one saved on My documents, iBike files (see attachment)
(21.9 KiB) Downloaded 663 times
Re: Scale units
Nope, try opening an explorer window to your main drive, usually "C" and search for *.ibr
EdgarCR
Re: Scale units
Post by EdgarCR »
sorry but I couldn't find this kind of file. All iBike's files are .cvs Thanks a lot
Re: Scale units
What version of the software are you using and which iBike do you have?
EdgarCR
Re: Scale units
Post by EdgarCR »
iBike 2 for window 2.0.1 My unit is IBikePro (purchased 2007) with cadence and speed wireless, firmware 1.18 thanks
Re: Scale units
So going back to the file you previously posted, I can't even open it. Last shot here, why don't you post one that does open correctly and I'll have a look at the differences.
It may not be salvageable but it's always worth a try.
Re: Scale units
EdgarCR wrote:iBike 2 for window 2.0.1 My unit is IBikePro (purchased 2007) with cadence and speed wireless, firmware 1.18 thanks
Please install the latest software, iBike Isaac, available at the download section of the ibikesports.com website. Then, try downloading your ride files again.
EdgarCR
Re: Scale units
Post by EdgarCR »
Thanks Fernando and Velocomp for your help. the problem was solved, I installed the new software version, now I have the new *. ibr files :D
