Ibike rides folder where all ride files are stored does not recognize new folders created under the ibike rides.
If you are a bike coach, you may like to create each rider folder and sort ride files out accordingly.
ibike rides folder doesn't recognize path
Re: ibike rides folder doesn't recognize path
I'm not sure what you mean. You can use the Edit/Preferences... menu item to change the folder where ride files are stored.
- Screen Shot 2012-10-19 at 5.21.11 AM.png (68.79 KiB) Viewed 7659 times
Let's say I created two new folders as below;
Documents/ibike rides/
Xxx60miles.ibr
Xxx32miles.ibr
New folder 1
/xxx.12miles.ibr
New folder 2
/xxx.45miles.ibr
For instance, try to open xxx.12miles.ibr
Always err message prompt, saying "path is not found".
Xxx60miles.ibr
Xxx32miles.ibr
New folder 1
/xxx.12miles.ibr
New folder 2
/xxx.45miles.ibr
Hmm, I keep the current month rides in
C:\Users\Fernando\Documents\Cycling Data\iBike\iBike Rides
and rides other than the current month in sub-folders:
C:\Users\Fernando\Documents\Cycling Data\iBike\iBike Rides\2012\09
On a PC but I have no problem accessing any ride in any folder when using Isaac or setting any folder I want as the preferred download folder.
Is this the default path velocomp made?
If so,
Then decuments/ibike rides/ was probably made by me to store old files.
It may give me answer! I will check it out tonight at home.
Thanks, racerfern!
If so,
Thanks, racerfern!
No, this is not the default path. It's my own creation and it's also what I selected via preferences.
