estimated friction in setup
donnybike
Post by donnybike »
When estimated frictional coefficient is entered under racer sequence in setup,
Does it alter the profile stored in ibike or intact?
In order words, when the est fric is set to no again,
Will ibike use the original profile?
Re: estimated friction in setup
When you change the number in the Racer sequence, that number is saved in all subsequent rides.
donnybike wrote:In order words, when the est fric is set to no again,
If you set EST FRIC back to NO, then the iBike goes back to the original profile, correct.
